Sparkplugs won't fire
Hello I'm new here,
My english is not the best but I try.
I'm installing an M48 on my BMW(S14 Engine) instead of the distributor, I have made disk and a Hall-sensor so I can use a wasted spark coil(2x2) and sequential injection. Also I have made a crankdisk 60-2 with a mag-sensor
-When I rev the engine, the signal of the crank-sensor is ok. (Measured with a scope) After the 2 missing theeth the Voltage goes in +, so in the setup I have enterd ''Rise''
-When I rev the engine, The signal of the Camsensor looked a bit strange??? it's constant 2V but when the sync point(it's round) arrives it drops to 0v, goes up to 2V en drops again to 0V then it goes to 2V (just like 2 sync points in one rev???)
Please look into the drawing.
Maby this is not the problem that the plugs don't fire, I don't now???(plugs, leads and coil are new)
The Fuel injectors are working.
-When I connect the scope to the primaire coil I CAN NOT see a good signal of the coil???
Hopefully someone can help me.
Thanks in advance.
Hans
Thanks in advance.
Hans
