M48 MAP sensor error
G'day. I'm running an RB30 on an M48 in a nissan patrol. The engine uses the factory VL/R31 inlet manifold and injectors etc, extractors on the exhaust.
I am using a delco 1 bar map sensor (green insert) which is being used as the load reference for the ignition map.
Every time the throttle is released from over about 3000 rpm, the output from the map sensor approaches 0V (high vacuum) and triggers a fault code within the motec. The map sensor is conected by a short hose ~300mm, directly to the plenum of the inlet manifold. Is there a delay value that can be set on error detection so as to ignore this momentary excursion in map output as an error?
