coil on plug or coil pack for 2.0L Jetta W/M4
Postby SANDRAIL on Thu Nov 12, 2009 3:12 pm
Hi! I want to do away with the distributor on my 1998, 2.0L VW Jetta engine and replace it with a Coil on Plug (COP) or wasted spark coil pack system. With the current mechanical distributor, the ignition system starts to break up at around 5K RPM's on the dyno. The engine is turbo charged (7-lbs boost) and mounted into a dune buggy so all of VW wiring has been replaced (with the exception of the stock VW coil and distributor) with a MoTec M-4 ECU. What can I use to meet my project goal?
SANDRAIL
Re: coil on plug or coil pack for 2.0L Jetta W/M4
Postby guiyote07 on Thu Nov 12, 2009 9:28 pm
Dear Friend,
A couple of BAE 801 Magneti Marelli coils and a 0227 100 200 Bosch ignition module works very fine in this engine.
Please see at M29 drawing for conections.
Mucha suerte
guiyote07
