Windows 7 issues...
Mon Nov 09, 2009 7:18 am
by majorcrimesracing
So the interpreter program is giving me an error saying: "The system does not support full screen mode. Please close the program" or something like that.
I haven't had this issue with XP and I assume the Dos integration is pretty similar so what gives?
I've tried running in a couple of different compatibility modes.
Re: Windows 7 issues...
Wed Nov 11, 2009 12:34 pm
by OmarK
In Vista/Windows7 the MS-DOS program has changed slightly. If you do a quick search of the Microsoft website you will see these changes explained in more detail.
One workaround solution for now is to keep the ECU Manager as a window but you may or may not be able to see the graph screen depending on your machine.
The second workaround is to install a DOS emulator program, there are a few out there, I haven't personally tested any of them so I can't recommend one but they allow the same functionality as was found in XP for some customers.
Fri Nov 27, 2009 10:51 am
by RossB
Whoa!!! DOS Interpreter! I think Noah used that when he was fine tuning the Ark! Install i2 and use that instead, it will change your life.
