problems connecting to motec
Postby nokia_aid on Tue Oct 13, 2009 8:48 am
iv got problems connecting to my motec m4 pro,my serial number is over 3000 so iv been told i just have to connect a serial cable into it which iv done but my laptop doesnt recognise it all all,iv tried a new laptop with a usb adapter and that didnt work so then i tried an older laptop with a serial port and still nothing,its on the right com port so i cant figure it out,
nokia_aid
Re: problems connecting to motec
Postby insomnia on Tue Oct 13, 2009 7:50 pm
i think you need to use the comm cable from MoTeC.
This cable use two D9 connectors ,on one side with "ECU" mark.
This side go on the ECU side...This is a Dongle in the connector.
Hope it's help!
Francois
insomnia
Postby NathanS on Tue Oct 13, 2009 11:45 pm
Francois, the MoTeC specific comms cable is only required for M8 and M48 ECUs all serial numbers and M4 ECUs with a serial number less than 3000.
I don't want to come across as being insulting but have you checked the basics, i.e. wiring to the ECU, does it power up? Check the 5V and 8V supply pins on the ECU connector to make sure it is actually on. Is the comms wiring to the ECU correct? As you are using a serial cable you only need 3 wires to pins 21, 22 & 23 on the ECU connector, there is a drawing for this which you can download from http://www.motec.com.au/m4/m4downloads/.
You mentioned that it is on the right comm port, I take it you checked this in Device Manager and then selected the correct comm port in the M4 DOS software by pressing F5 when at the Program Integrator menu screen?
NathanS
