Toyota idle control valve
Sun Oct 11, 2009 8:15 pm
by Fueltank-Tai
Dear Ross:
How to wire and setup a stock Toyota idle control valve unit ( 3 wires) for M4 pro. Thx.
Re: Toyota idle sensor
Wed Oct 14, 2009 10:21 am
by RossB
Are you talking about an Idle control valve or a sensor?
Re: Toyota idle control valve
Wed Oct 14, 2009 2:47 pm
by Fueltank-Tai
Dear Ross:
I mean that Toyota stock idle control valve which is with 3 wires . I want to know how to wire it . and setup . Thank you so much.
Wed Oct 14, 2009 3:54 pm
by RossB
If you refer to MoTeC Drawing V10 (attached) the setup is similar except for the following:
Pin 1 - Control
Pin 2 - 12V Power
Pin 3 - Slave
Frequency - 400
Wed Oct 14, 2009 4:25 pm
by Fueltank-Tai
I checked the idle control valve is with 3 wires.
Pin 1 --- control
pin 2 ----- 0V
Pin 3 ----- Ground.
Is it setup similar bosch idle valve ?
Thank you so much.
Thu Oct 15, 2009 9:04 am
by RossB
What model Toyota is this from? Do you have a wiring diagram?
Sat Oct 24, 2009 7:40 pm
by Fueltank-Tai
Toyota Echo 2000 year. I will give you the wiring diagram. Thank you so much.
