How to setup RPM limit Randomiser
Mon Aug 03, 2009 8:46 pm
by Fueltank-Tai
Dear RossB:
How are you? i have one question how to setup Rpm Limit randoniser function. Thank you so much.
Re: How to setup RPM limit Randomiser
Tue Aug 04, 2009 12:41 pm
by RossB
You just need to choose the number that gives you the smoothest cut. Normally 75 or 151 is used. The randomiser number is used in the calculation to determine the cut sequence.
Tue Aug 04, 2009 5:51 pm
by Fueltank-Tai
thanks RossB. How to adjust the randomiser number. Is it large number is hard cut or large number is sofe cut. Thank you so much.
Wed Aug 05, 2009 10:08 am
by RossB
I think you are confusing the Randomiser with the Control Range, it is the Control Range that determines if it is a hard cut or a soft cut. A bigger number in the control range wil make a softer cut. 200 is a typical value and for example if you have your RPM Limit set at 7000 with a control range of 200 the rev limiting would start at 7000 and apply a full cut at 7200.
