I just own my first MoTeC
Postby Rage Cayman on Sat Aug 01, 2009 12:31 pm
I am really excited to become a proud owner of a Motec ECu. I always like how this brand controls the cars I have seen is the USA fitted with Motec. I recently purchase an M4 from a racer in Orlando Florida, he told me that all the options such as wide band, data logging, etc are enable.I also buy a harness from a friend of mine in California, it has JGM Honda B" Series tag on it.I would like to use some of the outputs and understand the M4 in detailed, I am a very quick learner. When i was living in Cali there was a guy by the name of Shane T , I thinks he use to work at Motec USA, he show me alot of things in the newer M880 but my M4 looks totally different. I understands more of the M880 that on returning to my home land I was able to set up a M600 on a buddy Skyline and got it to start and idle. So I am searching for info and persons on this forum to help me set up my M4 on my turbocharged honda civic.
Rage Cayman
Re: I just own my first MoTeC
Postby Fueltank-Tai on Sat Aug 01, 2009 4:00 pm
Hi Rage Cayman:
How are you? I advice you to download the M4 manual to see it. basic loom sensors with the following :
1 3 bar Map sensor
2 intake temp sensor
3 water temp sensor
4 Crank sensor
5. cam sensor
6 injectors output
7 ignition output
I hope can help you . Thank you so much.
Fueltank-Tai
Postby Rage Cayman on Sun Aug 02, 2009 9:30 am
Thanks man. I would like to use the AUX output, Dig inputs
Rage Cayman
