Air Temp and Baro Press Comp...
Through a little research (read ChatGPT), I found out that the M48 does an Air Temp correction and Baro pressure correction automatically. Is this true? If so...
1. Air Temp Comp: says you can fine tune with comp table. Does that mean if the Air temp fuel comp table is zero'ed the M48 will do the correction based on its internal logic?
2. Baro Pressure: I have Baro Pressure on AuxV. How do I setup so M48 knows that so it can do its timing and fuel comp? Similar question to above -- should I zero AuxV fuel and ign comp table?
thx
Joe
thx
Joe
