Gear Ratio setting with TCMUX
Postby gixxer_drew on Sat May 23, 2009 10:21 pm
When setting up the Gear Ratios screen, it asks for the sensor calibration in pulses per rev. What do you enter in the case of using the TCMUX? With the TCMUX, the driven and non driven wheels can have a different number of teeth per revolution. In the case that they are the same, I assume you enter that number? What if they are different?
gixxer_drew
Re: Gear Ratio setting with TCMUX
Postby RossB on Mon May 25, 2009 9:35 am
You set this up in the Digital Input When you select TC Mux as the Digital Input function you set the driven wheel and rolling wheel calibration in the parameters.
