M4 on 4AGE 20V
PostPosted: Sat Feb 08, 2025 12:07 am
by Ekalogeratos
Hello
Sorry for resurrecting old tech, I figured its a shame to throw out the ecu because its old..
I am installing an M4 on a 4AGE 20V black top with a 24-1 distributor and a IEX .
IEX in is on IGN1 Pin33
IEX pins 3 4 5 6 have the appropriate ignition coil connected to them on firing order . ( 4 pin toyota cops)
Could I please have the settings that I should use for my setup?
I am thinking that for the 24 tooth wheel the ecu will measure every 24 teeth and know tdc for cyl#1
Can we trick it and also feed it cam position ?
Thank you
Re: M4 on 4AGE 20V
PostPosted: Mon Feb 10, 2025 9:31 am
I have attached the T11 file for setting up the 24 tooth distributors on a 4AGE engine.
The Ignition Type should be set to 100 in the Main setup window, and the number of coils set to 4.
Re: M4 on 4AGE 20V
PostPosted: Thu Feb 13, 2025 9:10 pm
by Ekalogeratos
Thank you very much for the file !
I am really looking forward in resurrecting this old dinosaur. :D
Re: M4 on 4AGE 20V
PostPosted: Tue Feb 25, 2025 9:37 pm
by Ekalogeratos
Dear Stephen Hello
Is the Aux 4 providing ground for the fuel pump control and the ignition ?
Thank you
Re: M4 on 4AGE 20V
PostPosted: Wed Feb 26, 2025 10:02 am
That is correct, Note 3 in the bottom corner explains the reasoning for this to be done.
Re: M4 on 4AGE 20V
PostPosted: Tue Mar 11, 2025 8:16 pm
by Ekalogeratos
Thank you for your support Stephen .
