M4 on 4AGE 20V
M4 on 4AGE 20V
Postby Ekalogeratos on Sat Feb 08, 2025 12:07 am
Hello
Sorry for resurrecting old tech, I figured its a shame to throw out the ecu because its old..
I am installing an M4 on a 4AGE 20V black top with a 24-1 distributor and a IEX .
IEX in is on IGN1 Pin33
IEX pins 3 4 5 6 have the appropriate ignition coil connected to them on firing order . ( 4 pin toyota cops)
Could I please have the settings that I should use for my setup?
I am thinking that for the 24 tooth wheel the ecu will measure every 24 teeth and know tdc for cyl#1
Can we trick it and also feed it cam position ?
Thank you
Ekalogeratos
Re: M4 on 4AGE 20V
Postby Stephen Dean on Mon Feb 10, 2025 9:31 am
I have attached the T11 file for setting up the 24 tooth distributors on a 4AGE engine.
The Ignition Type should be set to 100 in the Main setup window, and the number of coils set to 4.
T11 Toyota 24 Tooth Magnetic.pdf
(26.87 KiB) Downloaded 849 times
Re: M4 on 4AGE 20V
Postby Ekalogeratos on Thu Feb 13, 2025 9:10 pm
Thank you very much for the file !
I am really looking forward in resurrecting this old dinosaur. :D
Ekalogeratos
Re: M4 on 4AGE 20V
Postby Ekalogeratos on Tue Feb 25, 2025 9:37 pm
Dear Stephen Hello
Is the Aux 4 providing ground for the fuel pump control and the ignition ?
Thank you
Motec_edited_wiring.docx
(306.77 KiB) Downloaded 656 times
Ekalogeratos
Re: M4 on 4AGE 20V
Postby Stephen Dean on Wed Feb 26, 2025 10:02 am
That is correct, Note 3 in the bottom corner explains the reasoning for this to be done.
Re: M4 on 4AGE 20V
Postby Ekalogeratos on Tue Mar 11, 2025 8:16 pm
Thank you for your support Stephen .
Ekalogeratos
