Sync Status
Thu May 21, 2009 10:47 am
by p-racerj
can not get sync status to go ( OK ) - ref and sync sensor are state they are ok -Help
Re: Sync Status
Thu May 28, 2009 11:26 am
by RossB
Are you seeing an RPM reading when cranking? It would be a good idea to crank the engine with the plugs removed and see what errors are present while it is cranking. Remember that you will have to manually clear the errors while it is cranking and see which ones re-appear.
