M48 GETLOG Communications Errors.
I can get a connection established to the M48 ecu fine for tuning, however the GETLOG reaches varying levels of completion before throwing an errors.
Eg. Communications error
19
1D
1F
Etc.
The bigger the file, the worse it behaves.
Im running:
- The correct pci cable
- Windows 7 with a native rs232 serial port on coms 1.
- emp v6.20
- ecu v6.20
- data unload v6.14
I have emp installed directly on the computer and also an emulated version through dosbox. The dosbox version seems to work better for GETLOG, but still very flakey. Works fine for ecu connection.
If there is any guidance or workarounds, to get log files more consistently it would be appreciated.
19
1D
1F
Etc.
Im running:
- emp v6.20
- ecu v6.20
- data unload v6.14
