M4 and Rev limiter
M4 and Rev limiter
Postby AndersH on Fri Aug 02, 2024 7:29 pm
I have a challenge. Run a Volvo 240 Rallycar with M4, and when it is cold(about 5-10 degC) and hot(about 35-40degC) the rev limiter stops at 6000rpm. else it is 7800rpm.
Is there any option in the setup that these borders can be made?
Anders
AndersH
Re: M4 and Rev limiter
Postby David Ferguson on Sat Aug 03, 2024 2:33 am
Overboost? Mis-configured Gear Change Ignition Cut? Issue with the Ref Sensor?
I don't see anything in vers 6.2 EMP.
Postby Stephen Dean on Tue Aug 06, 2024 10:46 am
As David said, there is not a variable Engine Speed Limit in the M4 family of ECU's.
