Need Wide Band Controller for early M48
Postby EuroRace on Mon Aug 28, 2023 12:59 pm
I Have been searching for a wide band controller that will output 0-1 volt to be used with a M48 ecu.
I bought a AEM 30-0310 X and tried wiring in 2 resisters to cut the voltage down as explained on this forum,
viewtopic.php?f=10&t=3442#p15488, but I can not get it to work.
There has to be another solution. If someone has an idea I would greatly appreciate some advice.
EuroRace
Re: Need Wide Band Controller for early M48
Postby terryo on Thu Sep 14, 2023 8:43 pm
I bought a 2J9 unit thru Motec Qld. it works with my M4 and will work with M48
terryo
Postby stevieturbo on Sun Sep 17, 2023 5:19 am
Although they're annoying and often unreliable.
The Innovate outputs are totally programmable. So you can easily use one of those
Postby jtolson on Thu Oct 05, 2023 9:11 am
Post more detail in what you tried for the voltage divider. I just made one work with my M4 a couple weeks ago with a 5v output wideband so it's definitely possible.
jtolson
