M4 Opel c20xe CRIP and REF settings
Hello.
I am trying to setup motec m4 on opel c20xe engine, oem ecu is motronic 2.8.
crank has mag sensor with 60-2 wheel and cam (hall) is on exhaust and 1 tooth pointing in the same direction as exhaust lobe, so oposite of cylinder #1
TDC vs ref position should be around 120 degrees, I took out the sensor and counted how many teeth there are from TDC untill REF sensor is reached - 20
I have trouble to sync engine. I can start it, but it wont rev higher than ~2500rpm and there is poor idle.
I have ancient strobe light, without any options to see degrees, only live timing vs mark. While oem ecu was connected, I connected it and noticed that at idle its almost on point with the TDC mark. When I start the car on Motec, its way too early and i can see two marks ~ 10 degrees or more apart from each other.
Sadly I do not have the scope at the moment to diagnose futher, but I am shure that I have wired everything correctly, as I allready tried to swap mag sensor wires around and it was only worse.
Any ideas what I am doing worng are more than welcome.
Settings that "worked" to get it running with sync error
CYLS 4
rFSn 2
SYSn 1
rEF 11
cr T 60
TOr 20-80 worked did not notice any changes
criP 66
ign 1
COIL2
thesame as with these
CYLS 24
rFSn 2
SYSn 1
rEF 14
cr T 60
criP 120
ign 1
COIL2
CYLS 4
rFSn 2
SYSn 1
rEF 11
cr T 60
criP 66
ign 1
COIL2
CYLS 24
rFSn 2
SYSn 1
rEF 14
cr T 60
criP 120
ign 1
COIL2
