M4 Opel c20xe CRIP and REF settings
Postby Kalns on Wed May 24, 2023 3:55 am
Hello.
I am trying to setup motec m4 on opel c20xe engine, oem ecu is motronic 2.8.
crank has mag sensor with 60-2 wheel and cam (hall) is on exhaust and 1 tooth pointing in the same direction as exhaust lobe, so oposite of cylinder #1
TDC vs ref position should be around 120 degrees, I took out the sensor and counted how many teeth there are from TDC untill REF sensor is reached - 20
I have trouble to sync engine. I can start it, but it wont rev higher than ~2500rpm and there is poor idle.
I have ancient strobe light, without any options to see degrees, only live timing vs mark. While oem ecu was connected, I connected it and noticed that at idle its almost on point with the TDC mark. When I start the car on Motec, its way too early and i can see two marks ~ 10 degrees or more apart from each other.
Sadly I do not have the scope at the moment to diagnose futher, but I am shure that I have wired everything correctly, as I allready tried to swap mag sensor wires around and it was only worse.
Any ideas what I am doing worng are more than welcome.
Settings that "worked" to get it running with sync error
CYLS 4
rFSn 2
SYSn 1
rEF 11
cr T 60
TOr 20-80 worked did not notice any changes
criP 66
ign 1
COIL2
thesame as with these
CYLS 24
rFSn 2
SYSn 1
rEF 14
cr T 60
criP 120
ign 1
COIL2
Kalns
Re: M4 Opel c20xe CRIP and REF settings
Postby David Ferguson on Wed May 24, 2023 4:51 am
You should use your timing light and with IGNITION->Crank Index Position page visible, set the Test Advance to 0 deg, and adjust the Crank Index to get the TDC mark to align when using the light.
Postby Kalns on Wed May 24, 2023 7:23 am
Hey David, thanks for input.
And what about the rest of the settings, how can i figure them out ? I think that my issue is with cam sync settings, not so mutch with crank ref settings..
I will try that tomorow and report back with results.
Kalns
Postby Kalns on Thu May 25, 2023 3:44 am
So I tried what you suggested, entered menu - Ignition > crank index position
set test advance to 0 and while engine was running adjusted criP from 120 untill engine stalled at 130 and then from 120 to 115 when it stalled again. no change..
The think that I noticed is, that I see two marks at thesame time when strobe light lights up. both of them are apart visualy 15mm and thesame before TDC mark on the engine block.. I think there is my issue why engine cannot rev past 3k rpm.
Also worth mentioning.
Singe I am using OEM engine loom and only made jumper harness from motec to bosch 55 pin connector, I was not able to feed camshaft sync sensor 8v, it is connected to +12v and I am starting to think, that it might also mess things up here.. am I right or it should not be a problem ?
In general engine runs very poorly, almost no idle, have to open throttle to keep it running ~ 1300rpm and cannot rev past 3000rpm, missfires, like way too early ignition, after that and sounds like valves getting shut by expanding gases.
Kalns
