Toyota distributor Ref/Sync query
This refers to a 4AG engine with a factory dissy, where the upper sync wheel has had 3 teeth removed, ie it now only has 1 REF tooth. The lower 24 tooth SYNC wheel remains as factory
Motec drawing T11 for a 24 tooth magnetic Toyota dissy says the Ref/Sync mode should be set to 2 but thats not clear if it applies to a M4 or M4-8 or both
As best i can work out, that means the ref sensor is triggered on rise and the sync on the fall. can someone confirm that because its not clear in the help pop-up info
I have dug out an old tuning file from another Toyota using an identical dissy, and it has a mode value of 14. All help tells me is 14- multi-tooth, but again , no details
any input would be appreciated
