M4 Error Manifold Pressure
Can you advise what the error "Error Manifold Pressure" is on a Motec M4? I'm assuming it's set if there is an issue with the sensor.
See attached file... we are getting pops and bangs, similar to when you hit boost cut, so I assume the Motec assuming we've hit the limit.
Things which back my theory:
- you can see the MAP jumps to 300 kpa quite often, and this is when we feel the popping.
- it jumps there, no build up, so looks like an error MAP reading thrown by a sensor issue
Things which are odd:
- sometimes it shows the error when there is a perfectly acceptable MAP reading
- it doesn't throw a "Error Over Boost" (not shown in attachment) but maybe this isn't logged?
Note that this car is mapped to 2 bar (300 kpa) so the boost figures when not maxed out look normal.
Thanks,
Christian
Thanks,
Christian
