M4 Setup
Hi all, New to Motec. So I apologize for any lack of terminology or knowledge, learning as I go.
Finally put in a Motec M4 that's been sitting around. Also have the IEX expander as well.
Setup is a 4 cylinder turbo 2.0 3sgte Toyota motor, all wired up.
60-2 trigger wheel,
1 tooth cam sync using oem dizzy.
4 LS coils and 720cc high imp injectors.
Not having any luck getting it to fire. What is the recommended settings for the Ref/Crip and sync?
I have my ref sensor on 9th tooth after the missing tooth on trigger
I tried to set sync on about 270* BTDC, suggestion from a friend.
firing 1 3 4 2
I get sync error in diagnostic
Shows rpm about 200 to 240 while cranking
I know many of my settings are off, Looking for any help,
Any insight or advice is welcome.
60-2 trigger wheel,
firing 1 3 4 2
