ECU upgrade failed
Wed Mar 04, 2009 8:03 am
by Brede
I tried to upgrade the M4 ecu today,read/send/and program all looked wery nice,but now the ecu fail to get connected,it says SUU connected or connect ECU?? Anybody who knows how to fix this or do i need to send this to Motec? Local dealer have never seen or heared abaout this before.
Thanx in advance
Brede
Re: ECU upgrade failed
Fri Mar 13, 2009 4:15 pm
by JamieA
is the serial number of your M4 > 3000?
Did you use a striaght serial cable or a PCI cable?
What version of software did you go from and to?
Thanks.
-Jamie
Tue Apr 21, 2009 12:13 am
by SombiriE
We have experienced the same issue with our M4, I don't know which version they were going from or to but the result is the same. The serial # is greater than 3000, is there a method to reset the ECU back to where it was before? How do we fix this? I have attached a screen shot of the error message.
- Screenshot of error message
- motececu_error1.jpg (87.16 KiB) Viewed 16122 times
Tue Apr 21, 2009 12:47 am
by NathanS
Could you tell me what operating system was running on the pc that was used to upgrade the ECU, whether you were using a serial cable or a PCI cable and what connection on the PC you were using e.g. direct connection to the pc com port or a USB to serial converter.
One possible fix for this error is to connect the ECU to the PC as per normal and power it up but instead of opening the ECU Manager software go to C:\MoTeC\M4-v62 and double click on the Send.exe icon, this will launch a DOS window and should then resend the hex to the ECU.
If this does not work you will have to contact your MoTeC dealer and arrange to have the ECU sent back to us for repair.
Sun Apr 26, 2009 12:28 pm
by SombiriE
The PC was a windows laptop using a USB to serial converter. The guy that did it said he was trying to upgrade files but accidentally went into the upgrade ECU menu. I can't try the fix at the moment since our car is at competition but I'll try it when they return.
Mon May 11, 2009 8:48 am
by SombiriE
NathanS wrote:Hi,
I tried this last night and after the file loaded I was able to connect to the ECU. This fix works thank you.
