Motec M4 Aux V and Aux T inputs
PostPosted: Sun Feb 02, 2020 2:56 am
by xuzle
Hi
I have a gold box M4 wich i'm running in my e30 drift car with M50b25 turbo engine. Im currently wanting to wire in the aux t and aux v input to use for boost/ignition compensation and possibly to stage revlimit (via clutch operated switch)
But my question is, could i use 12v thru a switch and to the aux t and v inputs or do I need to use 5v as the manual says? Or can one of the inputs or borh be switched to ground?
I tried searching but could not find anything supporting or denying if it is possible to switch from 12v source
I'm currently in to wire the aux v from +12v and ground through a rotary switch and in to the ecu.
And then use the clutch switch with 12v in to the aux t input.
The reason to why I'm asking is that it's a lot easier for me to wire in 12v than splitting my ecu harnes to get 5v out to these two switches.
Regards
Re: Motec M4 Aux V and Aux T inputs
PostPosted: Mon Feb 03, 2020 2:07 pm
by SprinterTRD
Aux V and Aux T cannot be used with 12V.
Aux T has a internal pull-up resistor to 5V that can be used with 2 wire resistive sensors. IE temperature sensor.
Aux V is for sensors that output a voltage. IE Map sensor.
The two inputs can only read a voltage between 0 and 5V. From memory will go into error if 0 or 5V is input.
Digital input 1 and 2 have internal pull-up resistors to 5V and need to be grounded to activate.
