M48 Variants
M48 Variants
Postby Fozwanger on Tue Oct 22, 2019 6:04 pm
How do I tell the difference between an M48 Clubman and an M48 Pro?
Is there a simple difference such as a different serial number prefix?
TIA
Jeff
Fozwanger
Re: M48 Variants
Postby SprinterTRD on Wed Oct 23, 2019 8:35 am
The only way to tell the difference is to use the software and see if it has the advance tune upgrade enabled. If it has then its a PRO.
If it hasn't then the upgrade can be purchased and added to the standard ECU. This will need to be done through a MoTeC Dealer.
