Supercharged Jag V8
I'm fitting a blown Jag V8 into my hotrod and I have an M48 on the shelf that I'm going to use.
I have a couple of questions, the first is that the jag motor is sequential fuel (which is fine, the ecu can drive them individually) but the motor is coil on plug and isn't wasted spark system.
Can I run the motor with the 2 off ignition outputs and effectively run as wasted spark? Will this be detrimental or will it make no difference apart from the life of the coils and plugs?
Or would iot be better to use and ignition expander and run all 8 coils separately as per OEM?
Also, has anyone else used a motec on a jag set up and do they have a base map they're prepared to share to get me running prior to check for leaks etc before taking it to a dyno?
TIA
Jeff
TIA
Jeff
