Injector errors in log for M4
I recently got a Porsche 968 motor that sat for many years running again. It has the same M4 and map as when it last ran years ago. After a shakedown run at the track a couple weeks ago, I downloaded the logs and found injector errors. In approx. 4.5 minutes of logs, I see a few seconds worth of errors for each injector (injector 4 had the most at 18 seconds worth). The errors seem spread out during the 4.5 minutes. There are also a couple seconds worth of Sync errors in the logs. The EMP diagnostics screen shows OK for each injector. The engine seemed to run fine from a "seat of the pants" standpoint. The injectors are older Bosch units that I had rebuilt while the engine was being rebuilt. I saved the logs from this engine's last run years ago before the car was put in storage, and there aren't any injector errors.
Should I be concerned about injector errors in the logs? Thanks.
Scott
Scott
