Motec m4 intake temp sensor calibration
Sat Jul 07, 2018 7:22 am
by 4ndee
Hi guys I have an m4 on my celica st205. I brought an air temp sensor for my intercooler pipes and it came with a graph to calibrate it. The graph is ohms against temperature. When I go on the motec it wants to calibrate it using ad counts. Does anyone know how to convert this? Thanks
Re: Motec m4 intake temp sensor calibration
Mon Jul 09, 2018 9:41 am
by SprinterTRD
In the calibration table press F1 and it will give you the formula to work it out
Mon Jul 09, 2018 9:44 am
by adrian
The below spreadsheet is a resistance to A/D count converter, just fill out all of the cells in pink and it will give you the A/D counts to put into the ECU.
