Can a ref sensor be bad if Motec diagnostics says OK?
I have an older M4 on a Porsche 968 racecar, using a 52002 mag sensor for REF. I am pretty sure that for SYNC the stock Hall sensor is being used.
I am trying to start this engine after the car was completely disassembled after an accident and then sat for many years. Engine is freshly rebuilt. When attempting to start, all I get is belching out the exhaust, no real firing. Leads me to believe that something fundamental is wrong with ignition timing, REF, or SYNC. I've checked a few things to troubleshoot (more to do, I realize, but this is what I've checked so far):
- Motec diagnostics say OK for SYNC and REF (and everything else, save for an air temp sensor that is temporarily disconnected)
- Ignition timing appears to be correct on cyl #1. I verified using Motec Crip test screen setting while connected to the car, while cranking with sparkplugs removed. I used a timing light and TDC for cyl #1 mark on flywheel to verify.
- Fuel pressure appears to be correct (injectors are rebuilt)
- I smell light gas smell in intake stacks. I didn't think it was flooded. No real gas smell in exhaust.
- I detected spark on cyls #1 and 2 using the timing light
I am wondering about the 52002 mag REF sensor. It is set to .015" air gap per the instructions. Can it be damaged/bad even if the diagnostics say OK?
Thank you.
Scott
Thank you.
Scott
