New starter
I'm just finishing off my hotrod build and unsure of where to start programming the M48 ecu to get the car running.
It's a twin turbo TVR / Rover V8 using a custom inlet manifold with 8 injectors, MAP sensor and a honda s2000 throttle body to give you a rough idea of what I have.
For timing, I've gutted the dizzy and made a dual pickup using hall effect transducers that trigger on the falling edge of the pulse. (The reason I didn't use a trigger wheel is that I wanted to keep the look of a dizzy and leads and use a coil as I don't like the look of coil packs, EDIS or coil on plug). I don't want to use batch fire or wasted spark.
Would anyone have a base map for a V8 that I could look at to try and work out how to start programming the ECU please?
Thanks in advance
Jeff
Thanks in advance
Jeff
