AEM WIDEBAND 30-4900 WITH M4 (M2R) VOLTAGE DIVIDER
Hi guys, I know its kind of been answered before, but im seeking some clarification if anyone can chime in and give an answer.
(This aem gauge does not have the inbuilt divider option where you can change the voltage output at the back of the gauge itself.)
So to begin with, I have an aem 30-4900 wideband gauge... Runs the lsu4.2 bosch o2 sensor.... Now the gauge has 2 analog outputs + and -, gives a 0-5 v output.... the wires are + white - brown...
http://aemelectronics.com/files/instruc ... 0Gauge.pdf - PAGE 4 IS THE WIRING DIAGRAM.
Now question is: Can i successfully run an inline voltage divider between the gauge and the m4?
one of these: http://wbo2.com/faqs/autronic.htm
So it would be connected as: + and - from aem gauge, then voltage divider, then connect + and - pin 31 & 32 on m4.
The reason i ask is, through searching on the net people have done this with other widebang gauges and different ecus mainly autronic. However I emailed AEM and they told me you can not run a voltage divider to change the voltage out. Which confuses me as the output is after the gauge itself so it does not affect the gauge from what i can tell... Here is their email:
Unfortunately a voltage divider will not allow you to change the output signal from 0-5 volts to 0-1 volt on the Wideband Fail-Safe Gauge. Also the Wideband Fail-safe gauge will no longer read properly within the software calibration.
