Output Throttle Position Switch threshold via Aux?
I'd like to toggle some warning lights on the rear of the car upon throttle lift.
How would I map the TPS value below threshold crossing to an Aux switch.
It could be a pulse or fine to be on below X% as I will be sending it into a timer
that controls an LED flasher.
My car is pretty high compression, and I can often engine brake without braking before turn in sometimes
which catches folks off guard during HPDE events.
thanks,
Mike
thanks,
Mike
