Switch map on external stimuli
I'd like to run mixed fuel and send the M48 a signal to run a different setup file.
Is this possible?
Specifically I'd like to put a tap in my fuel line and have an ethanol tester send a signal to the m48, if the ethanol level drops I would switch out map files. I would either run ethanol or pump gas, dialing it back if I was just doing pump gas.
Alternatively I could do this at startup... or
Use the same map but cut back timing and fuel dwell.
Thanks,
Mike
Is this possible?
Thanks,
Mike
