M2r have a problem with injecotor max duty 2x 2200cc 2x750cc
Wed Oct 12, 2016 1:33 am
by imi
I shouldn't be at 93% duty at 1.2bar boost
I'm thinking it's somthing I've missed in setup
I've set the injector current to 0
Fuel table numbers go to 70 so scale seems to be OK on setting 12
How does the ecu calculate the injecotr duty ?
And what settings alter this thanks
Previously I had 4x850cc and I would only hit 90% duty at 1.5bar or close to that so I no its not the I jecotrs
Also is this because I have 2 diffrent size injectors
I've increased boost and seen the duty increase to aprox 105 I'm not getting any leaner so I'm certain I've done somthing wrong in settings any help will be appreciated thanks
Re: M2r have a problem with injecotor max duty 2x 2200cc 2x7
Thu Oct 13, 2016 10:28 am
by AdamW
If you can post a map and log I will take a look
Thu Oct 13, 2016 1:08 pm
by SprinterTRD
The injector Duty will be calculated on the smallest injector in the system.
Fri Oct 14, 2016 7:39 am
by imi
ive not put in any injector sizes just that the ratio between the 2 are 2.93 does it use this ?
also does injector timing effect the duty in anyway as i have small numbers in the table ad was thinking that i could increase the injection timing numbers i have it set to a stable setting as in the file
the injectors are bosch 725cc x2 ev14
bosch 2200cc x2 ev14 stubby
this is log
https://www.dropbox.com/s/lo2hea2nt2zym ... ty.ld?dl=0this is main tune
https://www.dropbox.com/s/m4xxawyv1uk37 ... t.T62?dl=0any defects im all ears thanks
Fri Oct 14, 2016 5:53 pm
by AdamW
In the map you posted you have the secondary balance set to 1.0, it should be 2.93 as you posted. Also in you secondary balance table you are commanding 50% of the fuel comes from the primaries, you should set this to 33% to get duty cycles of both sets to be similar (since your primaries will only flow 33% of the secondaries). I also think you will probably need to bring the secondaries in earlier to keep duty cycles reasonable.
Pics from your cal:
Fri Oct 14, 2016 11:18 pm
by imi
I am so sorry that's not the right file lol I have made so many saves
They save in numbers I'll upload the correct one soon as I get home sorry
That was the 4x 2200cc map I think
Fri Oct 14, 2016 11:25 pm
by imi
So not to use 50 but 33 this will max all injectors ?
As in my current ballance table I am using 50% assuming it was using the ratio I put in 2.93 to max both
Ahh because the diffrent sizes in injectors makes perfect sence will upload my current file then make changes and test and report back thanks loads
https://www.dropbox.com/s/ulpcmdduw5w46 ... 0.T62?dl=0
Sun Oct 16, 2016 11:50 pm
by imi
Thank you very much turns out it was just the ballance table as you have said
Thanks a lot for taking the time to look at the file
Need to go on another run to reduce the fuel numbers now many thanks
Thu Dec 01, 2016 7:52 am
by gkwestfrank
25% on your balance table will max out both fuel injector. i did one not too long ago, and to calculate the max fuel on the bal table would be 1/(1+inj ratio) X 100. so your come out 1/3.93 X 100, it is about 25%.
Thu Dec 01, 2016 10:45 am
by AdamW
gkwestfrank is right here, I'm not sure where my suggested 33% came from, possibly half asleep at the time.
