M48 setup advice realy using only ref sensor 36-2 no sync
4 stroke 36-2 ref (crank) no sync i have 4 coils running wasted spark
And 8 injectors
Ref sync mode is 81
Injector operation is set to 0 ( should it be set to 1 )
Im bit confused about what happens to the 8 injectors running non sequential (does it run semi sequential)?
does the injector ballance table still operate ?
I no it would be best to set up a sync but for now i would like to try setting up without
And 8 injectors
Ref sync mode is 81
