1996 subaru wrx cam sensor pick up fault
hi guys
i have a1996 wrx subaru jdm running on a m48 pro implant when its cold it runs fine but as it warms up after about 5 to 6 minutes it develops an error on the cam sensor input if i push the sensor in so that it actually touches the ferite rods on the plastic cam wheel it clears the error but it comes back when you stop pushing it in then it will not restart when its hot unless you push the sensor in again i have changed the sensor for a new one and tested the wiering for high resistance from the sensor to the ecu but it is all ok any sugestions guys ?????/
