My friend bought an Australian 1996 Turbo'ed Land Cruiser that came along with an M4 serial number 2244 that was installed as a piggy back on the stock ECU. We now rewired it to work as a stand alone but are not able to connect to it.
I made sure the power lines are good by testing the 5V output from Motec which is working. Since it had a female serial cable I quickly plugged in my USB to Serial adapter but couldn't establish connection. Googling around a bit brought up to me that the pre 3000 serial numbers are TTL and not RS232. I had a bluetooth module that I have been using on TTL's for quite some time but couldn't get that to work with the M4 either. Saw a nice clip on youtube showing how to turn your arduino into a TTL to USB (by grounding the reset pin) and that didn't connect as well. Finally, I had a true TTL to USB cable based on the CP2102 chip that came along with the Arduino Pro Mini that doesn't have the RS232 chip embedded. Results? No, that didn't work either!
Software used was EMP M4-V6.2 on windows 7. Although didn't find anywhere in the Motec software to change the baud rate still went in the device manager and changed the baud rate to 19200. Bottom line is that I tried everything I could possibly think of! Tried to even get something out of it using Hyperterminal but didn't see a bit of response at any give baud rates.
Ripped open the Female D9 and saw that the wiring was as follows:
Serial D9 Motec M4
Pin 2 Green Pin 22
Pin 3 Blue Pin 23
Pin 5 Yellow Pin 21
Based on the Motec's D9 Connections manual, it says that the above setup should only be for post 3000 series. For the pre 3000 series a Male connector should be there and the difference in these are that pin 5 of the D9 becomes pin 11 of M4 (Red) which is the serial ground. If these idiots identified each pin with their correct labels it would make life a lot easier.
If you want to learn how to complicate things you need to graduate from the Motec school. You might want to call this prejudice but I careless, I know the top guy in Motec is some smart guy in his own pants but the dumbest guy in the world that he doesn't know about.
Please if somebody can help me out with this connection it would save me from binning this shiny piece of useless crap.
