2200cc bosch injectors silly problem
Hey guys im on next stage of problem
I have installed larger injectors 4x 2200cc bosch
On the m2r the coil resistance is 9.1
And dead time is 0.45ms at 14v
Im trying to put the dead time into motec but failing i have set the injector battery comp to 4 for now
As the numbers in the box i cant make sence
At 14v its 780 is the 0.45 put into same box as 450?
And then what do i do for the other voltages
Also another problem is i have set the injector scale to 10
But the table values are to low and very rich so i had to trim the injectors to -40% better but would like to keep trim to 0 and sort it out properly thanks
Just found this can i use an avrige for between voltages ?
