m4- honda-modified dizzy- problems.
i have a honda with the jdm harness, m4 ecu. The cars crip is 120. IT runs anywhere from 50 to 120. I think that is a problem. With the timing set, it does not rev clean. Its a very rough idle and cleans up a little , but tuner thinks there is something wrong with my dizzy.
have a b18 running on wasted spark setup, msd dis2 plus ignition box cbr coils. Car has spark through the diagnostic section of the software. Timing is 9-12 degree at idle(same thing my other car runs)
Should i invest in a different sensor setup to make this problem go away?
using mode 2 for both ref and sync signals.
