help m2r ignittion output not what it should be
i just need an eplanation on whats going on i have seen all the coil configs on wiring the m2r up but im geating diffrent outputs to what i should be getting
my hall input is spot on going into ecu ref input pin 5 the power to sensor to pin26 and the 0v to pin 27
getting good squairwave while cranking 34 with 2 missing pulses thats fine
now the strange stuff
ignittion 1 pin 33 is supose to be connected to to leading coil but only giving out a sigle pulse
where as the ignition 3 pin 35 output is giving out the duel output twin pulse im only trying to seup from leading first
i cant explane whats going on
ether the motec wiring diagram is wrong or somthing in my settings is not right
Efficiency cal method 4
Load cal method 4
Load scail 250
Number of cylinders -2
Ref sensor type 1
Sync sensor type 1
Fef sync mode 83
Crank ref teeth 36
Tooth raito 50
Ignition type 102
Crip 45.2
Number of coils 4
Ignition dwell 3.0
Ignition delay 40
The number of coils i have changed to 1 butwhen i save it then re open program whlie running and tured off then start it goes straight back to 4
Currently leading coil is connected to pin 35 ignition 3 this output from ecu is the duel signal and reset the crip runs better butstill seriously misfiring
Load cal method 4
Load scail 250
Ref sensor type 1
Sync sensor type 1
Fef sync mode 83
Crank ref teeth 36
Tooth raito 50
Ignition type 102
Crip 45.2
Number of coils 4
Ignition dwell 3.0
Ignition delay 40
