M4 4.6
Hello all,
I have recently purchased a mk1 escort with a 2.0 pinto running Motec M4 and was told by the last owner that I can only run the 4.6 version of the M4 software, Could this be because my M4 unit is too old to update or should I be able to flash/update the unit and use newer software? if there is no good reason to update then I may also get an old laptop running xp with a parallel port and just use it for the car, I did get the parrallel to usb cable with it though!
Cheers,
Karl
Cheers,
Karl
