Fitting M4 ecu into a st205 celica GT4. Almost done
So the plan is to swap my motec ecu from one st205 loom to another.
so i have the pin out from the motec forum which is available on this link http://www.motec.com/forum/download/file.php?id=529&sid=b40e7cf3f2d60c30dec7a6a98fa4f751
heres a pic of the pinout
so ive been going through the existing wiring which i believe was done by Adrian at fensport and he then mapped it.
I noticed a few things which are different when ive been following the pin outs above.
starting with motec pin number 3 which should be injector cylinder 3 and wire colour Black-Red well mine is Black white and pin 15 which should be injector cylinder 2 is Black white instead of Black red so i t looks like these are the wrong way round. but does this matter if these cars are batch injection?
other things ive noticed are
pin 19 should be speedo input with an orange wire but i have no wire to pin 19 but i have an orange wire going to pin 20 and this then goes to a white connector which goes in the dash.
pin25 which should go to c13 goes somewhere else, maybe this doesn't matter if it is just a ground?
im not sure about the air temperature pins as I think only pin 29 is connected on mine and this is a grey wire
pins 30,31, and 32 have nothing going to them.
I have nothing going to pin 34 which is idle open RSO?
pin 35 has a black white wire to it but the pin out says it should be green - red / pink blue?
pin 36 goes to pin 4 on the main relay??
are pins 34 and 36 for launch control? as far as i know this was never setup on my car.
also how does the motec control the boost i notice there is a pin 13 for boost control but how does it control it, is there a standard solenoid somewhere it uses?
could it be that only the bare minimum has been connected up to map the car so some haven't been used?
thers quite a bit there but any help sorting these pins out would be most appreciated as i want to make sure its right instead of just copying what was already there in the other loom.
Another thing is the pinout and wire colours correct on that motec info sheet??
Thanks Guys
This is the car in question
Thanks Guys
