rpm gauge
PostPosted: Thu Jul 31, 2014 5:11 am
by andy_hstad
Hi I have a motec m4 where I do not have more outputs available and want to plug in the original tachometer in the car. The original tachometer was connected directly at the ignition coil but now I have 4 ignition coils connected in waste spark. can i hook up tachometer wire on ign 1 on motecet and get the rev counter to work?
Andreas
Re: rpm gauge
PostPosted: Thu Jul 31, 2014 2:44 pm
by AdamW
To drive a tacho from wasted spark coils you need to use a "ignition combiner" or sometimes called "tacho adaptor". Motec have them: http://www.motec.com.au/filedownload.ph ... docid=1203, you can find schematics online if you want to make one yourself, or available from companies like MSD also.
Re: rpm gauge
PostPosted: Fri Aug 01, 2014 9:36 am
by SprinterTRD
Unfortunately they are no longer available from MoTeC
Re: rpm gauge
PostPosted: Fri Aug 01, 2014 10:07 am
by stevieturbo
You may find the tacho in the car has an adjustable pot inside it that will allow you to adjust the reading for the reduced number of pulses from a single coil.
Or you could perhaps feed the 4 ignition outputs into a 4 channel amp, then combine the amp outputs to run the tacho ?
That should keep the ecu outputs isolated from the combined trigger.
Or maybe something like this ?
http://jaycar.com.au/productView.asp?ID ... TID=965#11
Re: rpm gauge
PostPosted: Fri Aug 01, 2014 12:04 pm
by AdamW
Re: rpm gauge
PostPosted: Sat Aug 02, 2014 2:16 am
by andy_hstad
thanks for all quick replays.
what do you think about doing like this
