Ref/Sync Mode Help
I have a Motec M4e system in a BMW E30M3. For years I ran it with both ref/sync sensors, 4 coils, and sequential injection. Now for a variety or reasons I need to take a step back and run a ref sensor only with the stock distributor and group fire injection.
My problem is this. I have a 36-2 crank mounted trigger wheel, but I do not see a ref/sync mode that will allow it to run this way. Modes 1-4 apparently require "one tooth per firing" which I presume would be a two tooth crank trigger? All the other ref/sync modes seem to require a sync signal.
It seems to me that if the M4 knows the number of crank trigger teeth, and has the CRIP for the missing teeth, it would have all the information it needs to run with the 36-2 trigger (with batch injection and a distributor).
Or do I have it all wrong?
Any advice appreciated.
