no spark
no spark
Postby andy_hstad on Mon May 19, 2014 8:06 am
Hey .I do not get any spark on my m4. I have constant speed from the crankshaft, no error codes and when I turn on the ignition, I get a spark on each cylinder but not when I run the starter motor, is connected as waste spark but four lights buddies via an ignition module according to schedule Ignition Module 4 Channel M37 # 41211th Anyone have an idea?
One more question how do I save my file on your computer so you can send it on when you do not have a floppy drive?
regards
andreas
andy_hstad
Re: no spark
Postby AdamW on Mon May 19, 2014 8:33 pm
You can use the ignition test function under the diagnotic menu to drive the ignition without the engine running, this will at least tell you that the wiring from the ecu to ignitors and coils and the hardware is ok. If you get a spark when performing this test then its either a ecu setting or perhaps 12v to coils is lost during cranking.
Your config files are automatically saved to your harddrive. When using EMP software take a note of the file name of the config that you want - it is usually an eight digit number. Then open up windows explorer, navigate to C:/MOTEC/M4-v62 and you will find your config in this folder with a T62 extension, for instance 03050800.T62.
Motorsport Electronics Ltd.
AdamW
Re: no spark
Postby andy_hstad on Wed Jun 04, 2014 6:40 am
Okay then, I have driven ignition test and it did not work first. But when I removed the cable that came from pin 36 which controls the relay to the fuel pump and tändnigs relay and put it directly to ground that worked ignition test perfectly. I can not split the signal from the fuel pump to the ignition relay? Can not have it's power to the ignition coil all the time.
Then I wonder what I should set when I have a 60-2 wheel to ref trigger. Inserting 71 and then I get sync error and no sync what am I doing wrong? And i one get 200 rpm with no pluggs
ref sync mode 71
crank ref teeth 60
tooth ratio 50
crip 84
60-2 ref
hall distrubiator 1 teeth
andy_hstad
Re: no spark
Postby AdamW on Wed Jun 04, 2014 11:33 am
andy_hstad wrote:Then I wonder what I should set when I have a 60-2 wheel to ref trigger. Inserting 71 and then I get sync error and no sync what am I doing wrong? And i one get 200 rpm with no pluggs
If you haven't already done so you should also try ref/sync modes 72,73 & 74 which are basically just different combinations of rising/falling trigger edges.
AdamW
Re: no spark
Postby andy_hstad on Wed Jun 04, 2014 3:07 pm
Okej i will test this. But is 70 mode the correct ref sync mode?
Regards
Andreas
andy_hstad
Re: no spark
Postby AdamW on Thu Jun 05, 2014 8:17 am
andy_hstad wrote:Okej i will test this. But is 70 mode the correct ref sync mode?
Yes, mode 7* is correct for an engine that has 60-2 on crank and 1 tooth on cam/distributor.
You can also use mode 8* in batch fire mode without the cam/distributor sensor but I would suggest mode 7* is the best choice.
AdamW
Re: no spark
Postby andy_hstad on Fri Jun 06, 2014 8:44 pm
I have one more queston should i have 60 on crack tooth when i have 60-2 wheel. I have no sync and sync error all the time and i cant find whats wrong. I have sync puls to the motec. Any ides?
sorry for my bad english
Regards
Andreas Wiberg
Andy_hstad@hotmail.com
andy_hstad
Re: no spark
Postby AdamW on Mon Jun 09, 2014 12:07 pm
andy_hstad wrote:I have one more queston should i have 60 on crack tooth when i have 60-2 wheel.
Yes, 60 is correct for number of teeth.
Do you have correct RPM showing on motec screen when cranking?
What type of engine is this?
AdamW
Re: no spark
Postby andy_hstad on Tue Jun 10, 2014 6:01 am
Okej. Det spark and sync error is fixed. But i hace one more question.
How do i set dead time comp and how do i set if i have low or high impedance injectors?
i have siemens deka 3145 788 cc injectors.
andy_hstad
Re: no spark
Postby Holmz on Tue Jun 10, 2014 11:11 am
andy_hstad wrote:Okej. Det spark and sync error is fixed. But i hace one more question.
Test them at various opening times, graph them up and draw a line through the points.
