the car has already been wired im just trying to clean the wiring up a bit and move the aux outputs around
my problem is
pin 33,34,35, aux 1, aux 2, aux 3,
pin 33 is connected to leading coil
pin 34 is connected to trailing front coil ( brown wire )
pin 35 is connected to trailing rear coil (brown/black)
my problem is on the setup its showing me aux1 e.g. pin 33 is thermo fan ?
i did mess with it a few years ago i may have changed it from coil but i cant seem to find coil on the selection
also aux 2 and aux 3 is showing ignition
by the way car is running but bit rough when revved car wont be moved till this is sorted thanks for your help all
http://i1199.photobucket.com/albums/aa4 ... 163225.jpg
http://i1199.photobucket.com/albums/aa4 ... 163236.jpg
