M48 or MLS for LS1
M48 or MLS for LS1
Postby DaleH on Wed Nov 19, 2008 9:02 am
Hi Guys
i have a turbo charged LS1 that i need a ECU for. i can get a second hand M48 with ignition expander for a good price but it is no cheaper than a new MLS so i have a few questions
can the MLS use the ignition expander as i dont want to run waste spark
can the MLS run 16 low impedence injectors as a fuel change to methenol will happen one day
can the M48 run 16 low impedence injectors.
thanks
Dale
DaleH
Re: M48 or MLS for LS1
Postby MarkMc on Mon Dec 01, 2008 3:06 pm
Hi Dale,
The MLS runs everything as groupfire anyway so it is going to still be waste spark. The M48 with ignition expander will be the only way to make it full sequential.
There is nothing wrong with waste spark many cars have been doing it for years with turbo's.
There is a current limit of 6amp per injector drive on the M48 so it depends on how low the resistance of the injecotr is.
Postby EF Motor on Fri Jun 19, 2009 5:26 pm
I'm bringin up this old thread.
Can the ignition expander be used with the mls to save some aux outputs for other stuf?
EF Motor
Postby RossB on Mon Jun 22, 2009 12:19 pm
Yes it can but you can only use 4 coils (wasted spark).
Postby EF Motor on Tue Jun 23, 2009 7:01 pm
If I understand you correctly, I can use all 8 ignition outputs on the expander, but it will fire two coils simultaneously?
Or will it only use 4 of the ignition outputs on the expander?
EF Motor
Postby RossB on Wed Jun 24, 2009 9:10 am
It will onnly use 4 outputs on the expander. You set the number of coils to 4 and wire it as wasted spark with each of the outputs triggering 2 coils.
