Is this M48 problem obvious?
I have an M48 and a 2 liter Cosworth YBM. At my last event the car died as a was driving slowly through the pits. Trying to restart it, it started to catch, but then nothing. A little later the engine started and ran fine till I shut it off, or for a minute or so. A couple hours later it did nothing other than crank as I ran the starter. At that point I had:
. Good battery voltage
. Fuel in tank
. Good flow after pressure regulator
. good fuel pressure
. The 2 fuel pumps ran continuously with the engine not turning, when they should shut down after a few seconds without oil pressure.
. No flow out of injectors
. No spark (not certain on this)
. fuses for ECU and pumps 1 and 2 are all OK.
It's now a couple days later and things seem similar, except that now the pumps don't run at all. I plugged in my windows 95 laptop with my RS232 cable and the engine seems to look OK, except of course it doesn't start. Diagnostics say that only sync is not OK, but that goes to OK when I crank the engine.
What should I look at? I could wire the pumps directly and look again for errors, but there seems to be a more fundamental problem.
. Fuel in tank
