m2r injector selector
Postby beefcake on Thu Nov 13, 2008 9:50 pm
ok i have the m2r on my 13bt and was just wondering what exactly is the leading and trailing injector selection, ie which wires are used for primary 1 and primary 2 and secondary 1 and secondary two, as i have no access to a wiring diagram purely for rotaries, as it only has a m4 setup for piston motors?
wire number 2 and 3 and wire number 14 and 15 on the m4 loom what are they for as in their primary and secondary numbers or doesn't that work like in a factory setup and they just all fire in a group setup
Thanks in advance
Im about to fire it up so there will be a few little other things id like too ask :)
Its a ida style throttle too with 4 bosch 1600 blues, so i really dont have a pri and secondary spot in the manifolds anymore :lol:
PB of 10.01@138 mph
http://www.youtube.com/watch?v=w2k_idn71ro
beefcake
Re: m2r injector selector
Postby RossB on Fri Nov 14, 2008 9:05 am
The injectors should be wired like this:
INJ1 2 Injector 1 Primary
INJ2 3 Injector 2 Primary
INJ3 14 Injector 1 Secondary
INJ4 15 Injector 2 Secondary
Postby beefcake on Sun Nov 16, 2008 9:26 pm
sweet i assumed correct (and i hate assuming) i shall leave as is :) , thanks for the help, i just forget at work to ring you guys and this forum and new website is a godsend for us forgetful types :lol:
PB of 10.01@138 mph
beefcake
