Boost control, any output?
Postby mr2daj on Sun Jan 06, 2013 11:29 am
Looking to add boost control on a spare output on my M4. i am already using AUX1 for Idle which can sink 4amps. The spare output i have can only sink 0.6 amps. Will i still be able to use this output? Is there a specific valve i need that will be low ampage or are they all pretty low? Wouldn't want to do any damage.
To test a valve i already have do i dust give it a permanent live and earth(100% duty) with a multimeter in line measuring amps?
mr2daj
Re: Boost control, any output?
Postby SprinterTRD on Mon Jan 07, 2013 4:56 pm
Have you checked the MoTeC drawings to see if there is a setup sheet for your valve?
