M4 PRO wheel slip information
The wheel slip for traction control can be calculated from the digital inputs(drive speed and rolling speed) no problems, I use that and it works fine. There is also a way of “Deriving the wheel slip from either the aux volt or aux temp input”, how does that work?
What kind of signal/information is that?
How do I generate that information?
Can I generate that within any other Motec dash or “box”?
Can I connect the speeds to a SDL3 dash and generate the wheel slip value within the dash and send it thru an aux output from the dash to either aux volt in or aux temp in of the M4 ecu?
/J
/J
